I have a 66F-100 4x4 im in need of some new leaf packs for the rear of the truck. The reason is i need to get rid of the blocks. Ive called several lift dealers and they say "sorry my book doesnt go back that far" I have 6inch skyjacker springs up front but i hate the add-a-leaf and blocks in the rear. If i remember right the distance from eye to eye on my leafs are 56 inchs if this helps.
Bronco Grave yard has springs for 67 up. I believe that the ones from '67 will fit. The only thing you should really have to worry about is the width. They have widths from 2" to 3", depending on the year. I THINK the 66 used 2" wide springs. They are $45 a pair for stock.
