No Spark!
Old Jun 30, 2004 | 06:30 AM
Cooder84's Avatar
Cooder84
Exclamation No Spark!
I have a 1973 Ford F250 with a 360. I have no spark. I have tried adjusting the points in the distributor, following ignition wires (found two that were bad, but I did replace them), replaced the ignition coil. Just wanted to know if there was anyone that could help me on this???
Old Jun 30, 2004 | 09:06 AM
beartracks's Avatar
beartracks
You could try running a jumper from bat hot to the + side of the coil. That would bypass the switch and wiring. If it starts don't keep running it that way. It will burn the coil.
Old Jun 30, 2004 | 09:07 AM
73Custom's Avatar
73Custom
Is there power to the coil?
Marty
Edit: Good idea with the jumper wire - eliminate it all at once...
