Checking oil
Old Jun 30, 2004 | 05:42 AM
SBV45's Avatar
SBV45
Checking oil
Here is an interesting bulletin from FORD:
Oil Level Check Tip:
When checking the oil level on the 6.0, the vehicle must be on a level surface and the dipstick must be fully seated into the tube to ensure an accuarte reading. Do not add oil if the level is above the "MIN" line on the dipstick. Broadcast Message 1512, 1574.
This is additional support to the theory that overfilling can cause some driveability problems and that you shouldn't replace more than 13.5 quarts on a oil change.
Old Jun 30, 2004 | 07:20 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Great info............and we needed this!
