please help with 93XLT questions
Old Oct 12, 2002 | 12:02 AM
screwy's Avatar
screwy
[updated:LAST EDITED ON 12-Oct-02 AT 01:10 AM (EST)]Hi everyone i was hopeing you could help me out my friend has a 93XLT with the 4.0L V-6 and it has started to make a loud clicking aroung the valve cover on the right side of the engine, only when put into drive or under a load but sounds fine in park even if you rev it only under a load, i wanted to know if this was a common problem with explorers or if its just bad luck, if you can think of anything let me know i will also post in the engine forum plus if maybe you could tell me the common problems with the 93 so i know what to look for that would be a big help. THANKS
P.S. about 120000 miles
96 Bronco, Eddie Bauer, 351w, auto
Old Oct 12, 2002 | 10:16 AM
mrshorty's Avatar
mrshorty
Is it valve or lifter ticking or does it sound more like spark knock/engine ping? Engine ping (from running lean) is a common complaint on the 4.0 L OHV. Usual fixes include: cleaning the Mass Air Flow sensor, replacing the engine coolant temperature sensor, fixing any vacuum leaks, retorquing lower intake manifold bolts/replacing lower intake gaskets. Here's a good resource for you. http://www.glue.umd.edu/~singletn/exp.html
Old Oct 13, 2002 | 12:21 PM
screwy's Avatar
screwy
its more of a valve/lifter type of sound which worries me
Old Oct 13, 2002 | 10:31 PM
bhdunbar's Avatar
bhdunbar
