Tachometer problems
Old Jun 29, 2004 | 05:38 AM
caprichos4's Avatar
caprichos4
Question Tachometer problems
Now that my headlights are working again I need help with the tach. This is a 97 Expi with the 4.6. The problem was persent when I purchased the vehicle last Oct. Remote start/alarm was added in Nov. ans still no remedy. The tach zeros out when turned off. I can start the vehicle ( I also have remote start) and the tach will jump to 2.5k right away. I don't have to accelerate or anything and it just goes there. There is about 25-50rpm movement of the needle when I depress the pedal, but it will return to that 2.5k mark. I had the 100k mile service done in Dec and the dealer said it looked like it was getting stuck when it got up the 2.5 mark. The dash illumination had 5 bulbs burned out, I replaced them and that's when I checked to see if the needle had enough clearance and there is plenty of room. Is this a common occurance? Is the sending unit to blame? Do I really need a new tach? I just don't know where to begin.
