1978 - 1996 Big Bronco
Adjusting speedometer with 6" lift?
Old Jun 28, 2004 | 11:36 PM
jaja's Avatar
jaja
I just got my truck back with a new 6" lift and 35" tires.
Since this is all new to me, I was wondering if someone could share some info about what to do with the speedometer (and maybe drivetrain) I know there some coupler that Skyjakker sells that is supposed to fix this problem.
My question is this: What else do I need to modify to help ensure the best ride on a lifted truck
jaja
Old Jun 29, 2004 | 12:20 AM
mrwizard's Avatar
mrwizard
A little more info on the truck would help.
Old Jun 29, 2004 | 06:28 AM
jaja's Avatar
jaja
'94 XLT 5.8 w/ ProComp 6" Lift
Old Jun 29, 2004 | 10:16 AM
Kemicalburns's Avatar
Kemicalburns
contact skyjacker i believe or superlift. they have a deal that plugs in to correct this.
Old Jun 29, 2004 | 10:48 AM
jaja's Avatar
jaja
I think its called truspeed from superlift. Has anyone out there tried this already?
Old Jun 29, 2004 | 01:54 PM
Fordbronco69's Avatar
Fordbronco69
Infidel
what size rim do you have?
the widder wheel base will give you a better ride/stability around turns.
My 2 cents
Old Jun 29, 2004 | 06:13 PM
jaja's Avatar
jaja
My rims are 15" x 10 with tires are 35" ProComp Xterrains
Old Jun 30, 2004 | 09:26 AM
Kemicalburns
My 2 cents
how would wider rim give you better ride and stability.
now a wider tire will do this, also if you run up to a 17" diameter rim vs the 15" you will get less sidewall flex and that to will improve handleing but may suffer some off road unless your running a 35" or taller tire.
Old Jun 30, 2004 | 10:01 AM
jaja's Avatar
jaja
Getting back to my question.... anyone have the superflift gizmo installed on their rig?
Old Jun 30, 2004 | 12:06 PM
Fordbronco69
Infidel
If you truck is lifted at 6" and have stock tires/rims you should be a little hesitant to go around turns at the same speed without the lift. The taller the vehicle gets the more TOP HEAVY it gets, meaning the widder wheel base, wider rim will give your vehicle more stability around turns.
Old Jun 30, 2004 | 12:22 PM
Kemicalburns
no body is gonna lift there rig 6" and not put bigger tires on it. but regardless wider rims mean nothing. other then letting you run a wider set of tires . but you can run an 8" wide rim with a 12.50 wide tire and get the same result.
now backspacing will make the tire/rim stick out farthur from under the fender and increase the width but go to much and will run into issues.
Old Jun 30, 2004 | 02:28 PM
InkDawg's Avatar
InkDawg
Man dont waste your money on one of those speed adjusters. I have a 95 and you can do it yourself by grounding the wire on the little plug under your glove box and changing the ratio on the digital speedometer. There is a write up on this site somewhere that tells you how to do it and even gives you the number to change it to. It takes like 5 minutes to do it and doesnt cost a dime. You can change it up to like 6 times. But you will get it right on the first time with the write up.
Old Jun 30, 2004 | 04:03 PM
jaja's Avatar
jaja
InkDawg - do you have a link to this write up?
Thanks
Old Jun 30, 2004 | 05:39 PM
InkDawg's Avatar
InkDawg
https://www.ford-trucks.com/articles...peedorecal.php
Old Jul 1, 2004 | 12:59 AM
jaja's Avatar
jaja
Thanks inkdawg... i hate to ask another bonehead question... but where is the "dealer mode programming enable single-terminal connector"?
