Bucking
Old Jun 28, 2004 | 09:41 PM
btmanpa1's Avatar
btmanpa1
Bucking
I have a 92 f-150 V-8 thats about all I know about the engine. I had the trans fluind and gasket changed about three years and 30,000 miles ago. I get this bucking or even a slaming from the transmission usually when the engines hot and I'm driving locally not on the high way. Mechanic told me awhile back that he may have to add an additive to the fluid. Does this sound right or any suggestions.
Old Jun 29, 2004 | 08:35 AM
rfxj3's Avatar
rfxj3
Fluid level?
You may have already thought of this but since it wasn't mentioned, check the fluid level. Mine was bucking quite a bit just after starting and trying to back up the driveway (35* slope) and found that I needed to add extra to just at or slightly above the top of the "full" line on level ground to keep it from happening. Once mine warmed up it was OK so you may have a different situation altogether. Good luck!
Old Jun 29, 2004 | 08:30 PM
btmanpa1's Avatar
btmanpa1
Mine seems to be the opposite. it really doesn't start until its warmed up
Old Jun 30, 2004 | 02:46 PM
mokujin101's Avatar
mokujin101
i have a 98 eddie bauer explorer.
im having the same problem, did anyone figure this out?
i get the hard bucking noise from the rear, when going slow, but on the highway its fine.
Old Jul 1, 2004 | 07:23 PM
btmanpa1's Avatar
btmanpa1
It doen't make much of a noise it just feels like the engine is almost surging. It's all in the engine nothing from the rear. As far as fluid I ckecked it when it was hot and it was ok.
