Horn Notes
Old Jun 28, 2004 | 03:52 PM
RaleighDad66's Avatar
RaleighDad66
Horn Notes
Can anyone tell me what the notes of the original horns were for the 66 F-100 series trucks? I don't find any references to pitch or freq. in the manuals. I expect they are on a beat frequency (dissonance) as opposed to harmonizing.
I'm wanting to replace the single horn currently installed with an original, dual horn configuration.
Old Jun 29, 2004 | 06:05 AM
William's Avatar
William
Most of these old Fords only had one horn. You will need to search the junk yards. Or just get a dual horn that you like.
Old Jun 29, 2004 | 08:09 AM
RaleighDad66
Wouldn't you know it's just one more thing... My harness is set up for two horns and it looks factory but only one horn is installed. Having said that, I don't see where the other horn would have mounted. The reason I thought the harness was correct is the horn relay and the first horn connection are on the driver's side. The spade lug has two wires with a factory-looking crimp and the second wire leads to a passenger side (existing) horn. I have tested that first lug and it is the horn circuit.
Old Jun 29, 2004 | 09:06 AM
FordBoypete's Avatar
FordBoypete
RD66,
By "66" Henry got a notion folk might be interested in more than Plane Jane F Series.
Although Henry had the "Custom Cab" option for some time by 66, it wasn't much until late 64 and then 65. . . By 1966 they had all kinds of goodies, the Ranger trim pkg w/ buckets & console, the 390 CID FE was available for those who whined & Moaned and you could get all kinds of "groups" like appearance, or comfort, or courtesy and so on.
By 66 seat belts, A/C, tinted glass, all sorts of stuff could be gotten if you coulld get into a sales & ordering manual. Also vehicles could be ordered in virtual custom configurations. So Henry made a lot of "fits alls" in the mid 60's. Harnesses are a good example of that practice.
FoMoCo figured it was cheaper to make harnesses with all possible combinations built rather than make special harness for each special combo. Thus we find our harnesses in our Slicks have wiring for many combinations on a V8 or an I-6 configuration basis.
You may find the "Dual Tone" Horn as an option in '66 sales brochures. Since FoMoCo uses "relay type" system you can add another horn to your slick. I ran a pair of horns from a '66 Lincoln Contenental "Suicude 4dr" sedan. I used a pair of horns from same vehicle to keep them in harmony. I think it sounds better than out of tune IMHO. Mine
sounded like Orange Blossom Special ripping thru central FL in 1940's & 1950's. . LOUD!
You can locate 2nd horn anywhere it fits or you want it by using a 5/16 tech screw, or self tapping bolt. Just make sure it has a good ground. It's plug & play too.
FBp
Old Jun 29, 2004 | 09:51 AM
RaleighDad66
FBp, That's exactly what I'm after - the Cadillac had one of the most recognized horn duos that I can remember and Lincoln must be right there as well. I know sirens are designed to be in a frequency range that accelerate the heart rate and adrenaline and I would be surprised if some of the same research didn't go into the pairing of auto horns. I definately want more than the monotone "toot" I have now.
Old Jun 29, 2004 | 10:17 AM
jcs1966's Avatar
jcs1966
You can buy horns but they are plastic and dont look original
Old Jun 29, 2004 | 09:08 PM
FordBoypete
RD66
I knew that. It's Exactly why I shared it with ya! They move people who don't turn around to look until after they moved out of your way doncha see?
Now If I could only get those dual, 30", tuned, Air Trumpets off that Peterbilt up my street I could re-arrange traffic on I-4 here.....ya know what I mean? It'd be worth hanging an air compressor on my slick!
Old Jun 30, 2004 | 05:13 AM
jowilker's Avatar
jowilker
Steve, Ya should go to any car that you like the sound of and get both horns (Ford family of course) and install them on your truck (removing the existing) and be good to go.
John
Old Jun 30, 2004 | 08:49 AM
RaleighDad66
Thanks all,
That will be the plan. Something that is more representative of the mass and era.
Old Jun 30, 2004 | 07:56 PM
FordBoypete
FWIW another 12v horn relay will work off the same grounding circuit of your horn ring/button and you can power up 2 more horns for a total of 4 with i push of the button/ ring.
That'd be good for New Years Eve I bet. . . .
FBp
Old Jul 1, 2004 | 10:05 PM
cdherman's Avatar
cdherman
Little intersting story --- I bought a VERY expensive core support for my 65 of ebay. It arrived with a horn as well. My body guys painted everything, but only installed one horn. I tested the other horn, and it worked, so I decided it belonged on the other side. Indeed, my wiring has a connector for the second horn and my core support has the holes drilled in the right place.
BUT, in spite of my most special efforts, I cannot seem to get the second horn behind the grille. Its like one of those chinese nail puzzles. It looks like it should go in easy, but no, it refuses!!!!! I think taking out the radiator would make it work.
But in the end, I got smart and realized that I had 2 "low" horns anyhow, and hooking them both up probably wouldn't have gained me much. So I put the project on hold.
Anyhow, thought it was a good "horn" story.
Old Jul 2, 2004 | 07:27 AM
William's Avatar
William
I'd like a huge loudspeaker connected to a cd of a train horn! Bet that would be fun for those SOB's in the passing lane doing 40mph.
Old Jul 2, 2004 | 07:38 AM
FordBoypete
My brother wants to make a "particle Beam" like the starship Enterprise has, I already ordered one from him. . . .
FBp
Old Jul 2, 2004 | 07:42 AM
RaleighDad66
My favorite horns were the air trumpets my brother had on his 76 F-250. But unlike FBp's idea, he only had an air tank mounted on the frame rail with no compressor and you had to fill 'er up everytime you made 5 good blasts!
66_F100
60
Dec 17, 2019 06:23 PM
gangstakr
Feb 1, 2014 09:19 AM
66f-100
20
Jan 19, 2012 02:16 AM
YoungFordAddict66
Dec 31, 2009 10:17 PM
FXDC4419
19
Mar 18, 2008 09:50 AM
