Sponsored by: Auxito
clicking sound from back....e brake?
Old Jun 28, 2004 | 03:50 PM
skinner3233's Avatar
skinner3233
2000 f-150 fwd 5.4 when i'm going slow with the windows down i can hear a weird clicking sound coming from the back rear i think...and it can be inconsistant.....is this my parking brake hanging up?...if so how do i fix it?
Old Jun 28, 2004 | 11:01 PM
Racerguy's Avatar
Racerguy
Possible warped rotor knocking the pads back and forth, or a park brake problem or maybe a U-joint.
Old Jun 29, 2004 | 07:06 AM
skinner3233
if i push in the park brake slightly it stops....so if it is my brake hanging up how do i fix it
Old Jun 29, 2004 | 01:14 PM
2001BlueCrew's Avatar
2001BlueCrew
clicking to clunking
My truck is in the shop right now, 01 F150 supercrew, I had a clicking in the rear end that grew into clunking. Thought maybe it was a U-joint, took it to the shop (ESP plan) and they determined it was in the rear end itself, week and a half later the truck is done, pick it up this afternoon, don't know the extent of the damage but it sounded over the phone that it was in the ring and pinion. My advice is to check it out quick.
Old Jun 29, 2004 | 07:12 PM
Racerguy's Avatar
Racerguy
skinner do you have rear drums or discs?
Old Jul 2, 2004 | 09:05 AM
skinner3233
i have rear disc
Old Jul 3, 2004 | 12:13 AM
Racerguy's Avatar
Racerguy
To check the park brakes you remove the rear caliper support and then the rotor. The park brakes are inside the rotor.
The cables sometimes stick and have to be replaced. The lever that pushes against the park brake shoes seizes up sometimes too. To fix that you pull it all apart and clean it thorougly and then put some anti-seize compound on the lever where it pivots and reassemble it.
