f-350 pickup
Old Jun 28, 2004 | 02:51 PM
DMAN's Avatar
DMAN
f-350 pickup
I would like to change the rear end in my truck to a dually and I found a rear end out of a 1 ton box van that has the wide frame like the ones on a single wheel truck. My ? is if the gears are different can you change the center or do they not come apart like the old trucks? If not can I just change the ring and pinion? The box van is an 88 and the axel code is 53 can anyone tell me anything by the axel code? The pickup is an 85 and the axel code is 53.Thank you
