trim question
Old Jun 28, 2004 | 02:01 PM
Talyn's Avatar
Talyn
trim question
Whats the trim peace under the lights and above the bumper called. Its the thin piece on the 91, i duno what other models it is on. Just want to finish out my list and such. =)
Need to do soonL:
New Tires - $441 - 235-60-15
New rim
Drivers side light
Finish Tune up
Need wires
Fix rear gas tank Seal.
Motor and transmission mounts
To do:
Check sensors
Rear right window replacement
Fix Truck bed
Zero Rust
Dents
Body rust
Window whipers
door windows
Fix window tracks
Tint new windows
door panels
Dash
cab trim
new carpet
clean cealing
Drive Shaft U-Joints
New cowl Grille
Fix drivers side fender
Replace IAC
Fix blend door
Replace rear bumper
Replace tail gate
Fix front gas tank
Paint job
Work done:
New oil pan
New Clutch kit
Master/slave clutch cylinder
Left rear wheel cylinder
Thermostat replacement
Radiator Flush/Fill
Heater Door (partial fix)
Replaced Thermostat
Greased U Joints
Fuel injector cleaner additive
Ball joints
Front end alignment
Exhaust fixed
New muffler, and tail pipe
Stereo
JL Audio 6.5s
KDC 222 changer (need to upgrade)
New Ball joints
Air Filter - K&N
TPS replaced
IAC cleaned
New Front bumper
PCV valve Filter
Rear Brakes
Fuel Filter
Old Jun 28, 2004 | 04:52 PM
boond0cksaint's Avatar
boond0cksaint
front bumper deflector, i believe
Old Jun 28, 2004 | 07:01 PM
Talyn's Avatar
Talyn
its not part of the bumper, its right above it.
the piece below it is the defelctor, the plastic piece.
Old Jun 28, 2004 | 07:46 PM
boond0cksaint
the piece under the headlights and above the bumper in my parts book calls this piece " deflector, front bumper stone. parts # f-17779-2a(this is what my '88 uses, $19.95 '87-'91) then the other one is f-17779-10a. the plastic piece under the bumper is called an "air deflector, lower front spoiler,below bumper,oe style repro. ('87-'91 part# f-001a06-6a) i could be wrong though
Old Jun 28, 2004 | 07:49 PM
Chris_ce's Avatar
Chris_ce
Filler panel
Here is a link to a picture of them http://www.americanbodyparts.com/cgi...BRONCO120.html
Had to ask the wife I forgot what they were called also.
Old Jun 29, 2004 | 09:24 PM
Talyn's Avatar
Talyn
actually, i found out, its called a vallance panel, not a deflector.
I found out from a parts guy, and remember a painter telling me vallance pannel.
