Alternator Problem I Think?
Old Jun 28, 2004 | 11:36 AM
coreycgate's Avatar
coreycgate
I've got a 77 Ford with 302. Alternator Charges with the truck running. My Question is: Can the Alternator drain the battery when the engine is not running? There is a wire running from the alternator to the solenoid. I am pretty sure its the wire that charges the battery. It seems to pull a load on the battery when the truck is off.
Old Jun 28, 2004 | 11:40 AM
pdqford's Avatar
pdqford
Yes. A bad diode in an alternator can drain a battery.
Old Jun 28, 2004 | 12:32 PM
dfisher1's Avatar
dfisher1
Corey,
More than likely, the voltage regulator causes the drain.
This is a problem I've seen from time to time.
Good Luck,
KingFisher
Old Jun 28, 2004 | 01:29 PM
coreycgate's Avatar
coreycgate
Thanks, I'll take it by my local alternator shop today to get checked out.
