Gas gauge question
Old Jun 28, 2004 | 10:51 AM
1987LTDmasta's Avatar
1987LTDmasta
Gas gauge question
i'm back..
anyway, i i just got done installing the rear tank from an '88 bronco onto my '86 F-150. instead of having the 2 tanks concept, i'm gonna axe the side tank and just keep the extra capacity rear tank.
anyway, i got a dilemma now. aparently, the gas gauge isnt reading right. it reads the tank as just over half full, when there's only about 2.5 gallons of gas ($5.00 of gas @ $2.01/gal)
is there a resistance difference between '86 and '88, or did i screw up on the wiring, or is the float thing bad? i checked the resistance to see if it goes up and down with the float and it read fine.
i had to hack the plugs since they were different, so could it be my fault?
also, the side tank never reads more than just over half a tank when its full, so basiclly when the side tank is full, it reads what the rear tank is reading now at empty.
anyone?
is my gauge bad?
Old Jun 28, 2004 | 09:52 PM
1987LTDmasta
i checked the gauge by grounding it out and it zoomed to F.
i also added another $10 of gas and now its reading about 1/2 tank LOWER than what it was...
very odd..
Old Jun 28, 2004 | 10:11 PM
Peach's Avatar
Peach
might be the sending unit..happened to me in my 87 f150.
Old Jul 4, 2004 | 10:55 AM
1987LTDmasta
figured it out..
it is indeed reading backwards (low resistance at empty, high resistance at full)
i'm going to buy a new sending unit from JCW that cmes with a new gauge. mine wont go past 3/4 unless you tap it.
fp_5
Oct 24, 2021 12:07 AM
merlynr
Electrical Systems/Wiring
Nov 26, 2008 12:38 PM
nflfreak43
Sep 8, 2008 08:54 PM
cjf5150
Sep 18, 2005 12:34 PM
