Aerostar Ford Aerostar
ABS/Cruise Control Dead
Old Jun 28, 2004 | 10:44 AM
M.Herrington's Avatar
M.Herrington
91 a*, 3.0, rear abs not working, light on. cruise control not working. just replaced sensor in rear differential, no change. any suggestions?
Old Jun 28, 2004 | 11:02 AM
copper_90680's Avatar
copper_90680
There is a black box mounted under the ashtray (or close to it). The box is held on by two nuts. That's the ABS control module. Check and see if the connector is loose, but I doubt it.
Old Jun 28, 2004 | 09:09 PM
roree's Avatar
roree
First, check that both brake lights work. The abs uses the filiments for ground. Check the brake switch that is either under the master cylinder or in it. I forgot the switch name but if you search this forum you will find tons of stuff on this topic. Good luck.
Old Jun 28, 2004 | 09:37 PM
M.Herrington
yes, both lights work
Old Jun 28, 2004 | 09:39 PM
Muffinman's Avatar
Muffinman
The switch in the front of the master cylinder with two wires. It's just below the filler. It's made of plastic so unscrew it easy and check to see that no junk is in the port and the o-ring is good.
