Help...serpentine belt!!!!
Old Jun 27, 2004 | 04:37 PM
canadianfirefighter's Avatar
canadianfirefighter
Being the idiot I can be at times, I replaced the water pump on a 5.0 and forgot to make note of where or how the belt goes back in. There is no AC and its a 2wd with6 pullies and the tensioner.
Old Jun 27, 2004 | 05:35 PM
canadianfirefighter
Welll...after a double Crown and Coke things looked clearer. I figured it out! For anyone that cares:
1/ Start on the left side of the water pump
2/Wrap the belt around the Power sterring pump and the AC or spare pully above to the right of the water pump
3/Wrap the bottom part of the belt around the Crank pully and the Compressor
4/Take a 1/2" socket or wrench and bring the Tensioner up
5/Put the belt around the Alternator and under the Tensioner and slowly release the pressure on the socket or wrench
Old Jun 27, 2004 | 06:59 PM
drewcoolness99's Avatar
drewcoolness99
Old Jun 27, 2004 | 09:36 PM
acerockola77's Avatar
acerockola77
There should be a diagram on your hood, also.
