Aerostar Ford Aerostar
replacing the cv shafts ?
Old Jun 27, 2004 | 02:19 PM
fordnut71's Avatar
fordnut71
i got a 4 wd aerostar an i got a bad cv shaft on my drivers side an id like to know what is the best way to change the shaft out . i cant seem to see where i would get enough room to take it out . so im sure some 1 has changed it before me so if u have plz let me know what pain im in for lol
tks every 1
mark
Old Jun 27, 2004 | 05:15 PM
fifteen+'s Avatar
fifteen+
seperate the ball joints from the knuckle and remove caliper and undo axle shaft nut and remove knuckle assembly, remove front shock (recommend replace while in there) and remove rubber bounce stop and the axle should squeak out of there.
Old Jun 28, 2004 | 12:58 PM
RPinNEB's Avatar
RPinNEB
Symptoms
Just curious, what were the symptoms that are causing you to replace
your CV joints? My Aerostar has a clunk that I'm trying to find.
Old Jun 28, 2004 | 04:33 PM
Muffinman's Avatar
Muffinman
You can check your motor mounts. Aerostars have a problem with them tearing the joint apart which makes that clunk sound.
Old Jun 28, 2004 | 04:40 PM
aerocolorado's Avatar
aerocolorado
Front end 'clunk' has several causes. Loose shock mounting bolts, worn sway bar end links (common), worn upper ball joint (more common) or worn wheel bearing. CV joints don't clunk unless the axle nut is loose on the bearing hub. On the E-4WD versions if the rubber isolators suspending the front differential have separated, the differential can be resting on the front cross member producing a big 'clunk' and constant whirring/grinding noise. (very uncommon) As previously mentioned, motor mounts can cause noise, but have been rather rare problems on the Aerostar.
Old Jun 28, 2004 | 04:48 PM
copper_90680's Avatar
copper_90680
My '93 Aerostar has a cluck in the front end, and it came from the lower balljoints, which I was told rarely ever went bad. But I guess 150,000 miles does a lot to the suspension. Replaced it for about $35 in parts and a case of beer.
Old Jun 30, 2004 | 05:59 PM
fordnut71's Avatar
fordnut71
ok its more of a click an clack when i make a turn .the boot is torn an the grease is all missing . also many years of having a front wheel drive car is telling me is worn out . but i found out today the hard way not to cut out the old 1s an think u can run in 2 wheel drive . so 2 new shafts are on order an to be replaced tommorow . so ill be putting them tips to work then lol
tks
mark
Old Jan 26, 2005 | 05:02 PM
unluckyfrank's Avatar
unluckyfrank
I have the same problem with my 97 e4wd, cv joints need to be replaced.How big a job is it and how long could it take to do? Two feet of snow and 0 degrees might slow me down a bit!
Old Jan 26, 2005 | 08:01 PM
fordnut71's Avatar
fordnut71
well as it says up top replace your shocks am undo your ball joints u will be able to just sneek the old 1s out an the new 1s in . when i did mine a few months back the machanics price guide for this job said 3 hours an i did mine on the floor with no air tools in that time an that was both of them it will take u a bit with the 1st 1 to see how it comes out an goes in . once u see the next 1 will be 1/2 that long
good luck
mark
blacklab1
1978 - 1996 Big Bronco
Sep 14, 2011 08:45 AM
ErrorS
Mar 31, 2010 01:38 AM
acm05fsu
1997 - 2003 F150
May 3, 2007 07:31 PM
Ryan50hrl
Offroad & 4x4
Apr 16, 2004 06:32 PM
kburch
Bronco II
Nov 8, 2001 07:15 PM
