need rearend knowledge
Old Jun 27, 2004 | 07:47 AM
ford190082's Avatar
ford190082
i recently tuned up my 351w, when done i took it out for a test everything was excellent , next day i noticed a puddle of diff fluid i check and it was diff
now i noticed the the diff yoke has came a head about an 1 1/2, what is the best way to fix this.
the diff still functions properly
a little too much weight on the gas peddle i guess
Old Jun 27, 2004 | 08:03 AM
ford190082's Avatar
ford190082
Differential
i recently noticed a leak from my differential
upon checking it i noticed that the yoke has come out an 1 1/2 from the housing how can i correct this problem
Old Jun 27, 2004 | 08:32 AM
WhëëlMå1's Avatar
WhëëlMå1
You might want to ask the guys over in the Transmission, Differential, Axle and Transfer Case forum. Sorry I cant be of more help.
Rich
Old Jun 28, 2004 | 01:12 PM
Dakota 4x4's Avatar
Dakota 4x4
sounds like the nut that holds the yoke to the pinion has come loose. the problem is how much damage has occured to the pinion bearings and other interal parts. the very least you would have to do is replace the pinion seal and reset the bearing preload and hope that the nut stays put. You have to be careful not to overtighten the nut that holds the yoke. That is the tricky part if you want the differential to last it has to be just right.
Old Jun 30, 2004 | 08:05 AM
Charles in AZ's Avatar
Charles in AZ
I agree with the previous poster that you may have damage to the ring and pinion from running with major misalignment. This problem mostly results from a previous "mechanic" not using a new yoke nut when servicing the rear axle. If the ring and pinion are still good, replace both the seal AND the nut. The service manual for the 8.8" rear axle states (I'm sure that's what you have) that the nut should be replaced, not reused. It come with a locking sealer on the threads. If you can't afford a new nut, at least use Loctite locking sealer on cleaned threads and check it a lot.
Old Jun 30, 2004 | 03:09 PM
alcan60283's Avatar
alcan60283
You need to replace the lock nut that holds on the yoke. It has some lock tite on it so you really shouldn't re-use the only one unless you put some more lock tite on it. I would also replace the crush sleeve while you're at it, and then just tighten that nut down REAL good. Use a cheater pipe. Not sure on how much to tighten exactly, i would do a search on that . Good luck.
Old Jun 30, 2004 | 03:38 PM
pdqford's Avatar
pdqford
If'n this is a 9", it can take upwards of 300 ft/lbs to crush a new sleeve. Prolly have to have two cheaters - one for the nut and one to hold the yoke
Used pinion bearings in a 9" calls for the nut to be tightened until it takes 8-14 INCH/lbs to continually rotate the pinion with the axles REMOVED.
