93 e-150 intermitted fire
Old Jun 26, 2004 | 06:44 PM
mjguit's Avatar
mjguit
I'm pulling my hair out here.. I have a 1993 e-150 with a 300/6.. Spark seems to come and go, i have replaced the module, pickup coil, and ignition coil.. I have checkd the negative at the coil and sometimes my test light does blink as engine turns and the engine fires.. It may run 5 seconds or 5 minutes then cut off. then there is no spark and test light wont blink.. Wht do i check next..HELP..
Old Jun 26, 2004 | 10:16 PM
Franklin2's Avatar
Franklin2
Check to see if you have any computer error codes. If one comes up saying a missing PIP signal, I would suspect maybe the wiring from the module to the computer may be frayed or shorted.
