3.8 Engine swap
Old Jun 26, 2004 | 05:30 PM
64galaxie500's Avatar
64galaxie500
3.8 Engine swap
Can anyone tell me if a 3.8 from a 96 Windstar will fit in any late model
(90 and up) Ranger pickup?
Old Jun 26, 2004 | 07:13 PM
Racerguy's Avatar
Racerguy
Hi and welcome to the forum
Rangers never came with 3.8's in them so it wont be a direct bolt in but I dont think it would be all that hard to do if you had a RWD transmission from a 3.8 in a Mustang or whatever as well as the wiring harness, PCM etc.
Old Jun 29, 2004 | 01:32 PM
99F150's Avatar
99F150
The windstar engine may be different then the 3.8 from a rear drive app. You would be better to look for a 4.0V6
Old Jun 29, 2004 | 02:04 PM
64galaxie500
thanx for the info!
Old Jul 3, 2004 | 09:21 AM
3Lstroker's Avatar
3Lstroker
I have considered this swap before.. I would love to have the torque of the 3.8 in my ranger. The biggest problem would be clearance on the passenger side to the evaporator box. The 3.8 is a 90 deg V and has the same deck height as a 351!!! Major surgery to the box. May even lose a/c all together. The mustang 3.8 and the windstar 3.8 are a different block. The mustang 3.8 has the 5.0 bellhousing pattern and the windstar has the 3.0 bell pattern. Another major hurdle may be the flexplate/flywheel. The windstar never came with a stick, so you will prob not find a flywheel to fit, would prob have to run the auto and I would not hold my breath to the a4ld holding up to the torque of the 3.8 very long. It would prob be alot more feasible to use a mustang 3.8 and tranny than a windstar 3.8....
Old Jul 4, 2004 | 02:05 PM
64galaxie500
Hey thanks for the great info! Also Thanks for your reply.
