rod bearings
Old Jun 26, 2004 | 02:11 PM
ford390gashog's Avatar
ford390gashog
Talking rod bearings
how do i tell which oversize or undersize bearings too use
Old Jun 26, 2004 | 10:00 PM
Dealford's Avatar
Dealford
You'll need to measure the journals on the crank & post the numbers here.
AL.
Old Jun 26, 2004 | 11:46 PM
ford390gashog
ifound these numbers on the bearings when i removed them it says .010 is this a oversize or undersize bearings
Old Jun 27, 2004 | 12:27 AM
led sled's Avatar
led sled
that means the crank was turned, so you will need an oversized bearing. when you turn the crank your taking metal away, so you need a larger bearing to compansate for the loss.
