2001 coolant capacity?
Old Jun 26, 2004 | 11:41 AM
Smokeater11's Avatar
Smokeater11
My Manual does not have the diesel supplment book. I'm looking for the capacity so I can read my test strip right.
TIA
Old Jun 26, 2004 | 11:52 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Eight gallons according to the book, but with mine completely drained (including the block) it holds right at seven. What test strips are you using that you need to know the capacity?
Old Jun 26, 2004 | 02:55 PM
Smokeater11
I'm using Fleetguard 3-Way Coolant test strips. And when I figured it out it came to 0.6 and to caculate how many pints I need to put in it said I need to know what the capacity of my truck is.
Another dumb question! when I add the additive do I just add it to the white bottle on top? If so will it mix from there?
thanks again for the help
Old Jun 26, 2004 | 04:07 PM
jschira's Avatar
jschira
Put the SCA in first then the coolant.
It will mix out of the degas bottle, in about 100 years.
Old Jun 26, 2004 | 04:29 PM
Smokeater11
No really do you add it to the degas bottle or do you add it somewhere else?
Sorry dumb question, but I don't know. Looked for somewhere else to add it but could'nt find anything.
Old Jun 26, 2004 | 10:53 PM
Smokeater11
Could someone tell me if adding the additive to the degas bottle is correct?
TIA
Old Jun 27, 2004 | 12:36 AM
cookie88's Avatar
cookie88
FTE Emeritus
The de-gas bottle is the only place you can add it, unless you want to pull the top radiator hose or are doing a coolant change. Just dump two pints in it and call it good.
Old Jun 28, 2004 | 09:10 AM
Smokeater11
thanks for all the help guys. Nice having people around that will answer stupid questions without getting mad.
SirBunnyEater
Feb 22, 2016 07:11 PM
twinpeaks
Mar 6, 2010 10:06 AM
Woodsman_30350
May 20, 2007 08:55 PM
paradiddle
Modular V10 (6.8l)
May 22, 2004 07:21 AM
cakewalker
1978 - 1996 Big Bronco
Dec 2, 2001 08:50 PM
