Puller!!
Old Jun 25, 2004 | 06:32 PM
Big-EEE's Avatar
Big-EEE
Puller!!
About 8 months ago I purchased a 2003 F-250 7.3 diesel 4x4.
It recently was raised 4 inchs and has 35 inch tires and 16x10 rims.
I went with the double shock steering stablizer up front and the double front shocks. I have 373 gears with no lockers or limited slip. I would like to go with a 456 gear and a rear detroit locker and some version of a sellectable up front.
My question is am I going about this in the right way. My final goal for this truck is to make it a puller truck.
Old Jun 25, 2004 | 06:35 PM
johnsdiesel's Avatar
johnsdiesel
What are you going to pull? Lifting your truck never improves performance when towing, it makes it handle worse.
Since you started out with 3.73 gears, the gear change is the only way to go if you want to tow anything substantial.
Old Jun 26, 2004 | 12:55 AM
Kwikkordead's Avatar
Kwikkordead
Yeah, if you want a puller sell that one quick and get one that is setup for pulling in the first place. You could convert it to what you want but it would be cheaper to sell that one and buy one that is already properly configured.
Check my gallery. I bought this truck about a month ago after learning the hard lesson that an f-250 will eventually break an axle trying to pull a 13000 pound trailer.
Old Jun 26, 2004 | 10:21 PM
Frost13's Avatar
Frost13
It depends on how much you are towing. My guess is that with 35's a 4.10 should be fine.
Old Jun 26, 2004 | 11:29 PM
psdpower's Avatar
psdpower
Big EEE, do you mean tractor pull?
Old Jun 27, 2004 | 01:37 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
A dedicated puller should have lockers or spools in both ends, but they may not be legal if you intend to run in the stock classes.
