compression
Old Jun 25, 2004 | 03:17 PM
led sled's Avatar
led sled
Thumbs up compression
well since i got to go through my motor, i was thinking about shaving my heads to up the compression some. i'm running edelbrock rpm heads with speed pro forged pistons. i figure i have around 9-1, 9.5-1 comp right now. i would like 11-1 comp. is this possible? also i'm running 175 hp shot of nos, would 11-1 comp be too much for nos?
Old Jun 25, 2004 | 04:17 PM
fordeverpower's Avatar
fordeverpower
is this ever going to see the street again. tunnel ram, dual quads, 11 to 1 cr. .010 of the heads is worth like .2 or.3 max cr increase. taking .020 off would get .5 cr more. So no!
Old Jun 25, 2004 | 04:22 PM
Scouder's Avatar
Scouder
Your ability to raise your compression depends on a several things, among them:
Your cam.
Your cams installed specs.
Your altitude.
Your timing.
Your fuel.
The weight of your vehicle.
If you can raise your compression, I wouldn't cut a nice set of heads to do it. You might try a set of steel head gaskets, which are fairly thin.
Unfortunately nobody will be able to say for sure if you can raise it or not. It's a judgement call.
-Scouder
Old Jun 25, 2004 | 04:52 PM
led sled's Avatar
led sled
so maybe my best bet would be to find pistons with a higher compression ratio? i agree with you scouder, i don't really want to cut up my eddy heads !
Old Jun 25, 2004 | 05:08 PM
gtex's Avatar
gtex
you should be able to get plenty of power in the 9-9.5 range. Just get the rest of the motor to compliment that, mainly the cam.
plus, you can run on regular gas. At 11:1 you might run into issues with lower octane juice.
Old Jun 25, 2004 | 10:57 PM
led sled's Avatar
led sled
my buddy just said the same thing !! he said it ran good before don't screw it up !! i guess i'll just buy the forged 390 crank and my dual quad set-up ( mainly for looks ! ) and the nos for the dual quads.
Old Jun 25, 2004 | 11:32 PM
gtex's Avatar
gtex
if you want loooks, get a 6-pack. The yare on ebay all the time and the ylook the coolest to me. I'm sure they take some tuning, but it might be worth it.
Old Jun 25, 2004 | 11:36 PM
led sled's Avatar
led sled
i'll have to look into that, but i don't think i could use my nos with a 6 pack? i do like the way they look though :-) !! you got me thinking now !
Old Jun 25, 2004 | 11:58 PM
Randyb12's Avatar
Randyb12
The Edel heads and SpeedPro forged flattop pistons give you 9.68:1 with the felpro head gaskets.
Old Jun 26, 2004 | 11:15 AM
led sled's Avatar
led sled
really !! thats better then i thought ! thanks for the great news randyb12 !
79blakemaggard
17
May 1, 2015 11:43 AM
wedefyu
Mar 4, 2008 04:44 AM
eperky
Dec 30, 2007 09:34 PM
big muddy
Nov 17, 2004 09:07 AM
satx77stepside
Nov 10, 2003 07:25 PM
