Keyless entry pad programming.
Old Jun 25, 2004 | 03:41 AM
socalexplorer's Avatar
socalexplorer
Unhappy Keyless entry pad programming.
I recently purchased a 1999 Explorer Limited. It has a keyless entry pad. I purchased it from the dealer and they did not have a code for it. The dealer said they could reprogramit if they had to old code but did't. How can I get this pad reprogramed>
Thanks for your help in advance!
Old Jun 25, 2004 | 07:53 AM
mason's Avatar
mason
Should be on the receiver box located in front of the jack. Remove jack area panel. There should be a small box with wires going into it just in front of front part of the opening. A sticker should be on the box with a five digit number on it. A flashlight and an assistant to pull out the panel from the box will likely be needed.
Mason
