broken shifter?
Old Jun 24, 2004 | 11:32 PM
edselman's Avatar
edselman
Unhappy broken shifter?
A guy selling a truck I am interested in says that something is broken on the column. It is a automatic. He says basically that instead of using the lever to change from p,r,n,d you have to turn the column to put it into gear. Is this a sign of a serious transmission problem? How expensive is it to fix?
Dane
Old Jun 24, 2004 | 11:49 PM
Faithful Old Road Dog's Avatar
Sounds like a column shifter problem. Take it for a spin and see how it shifts. When you put it in drive see how the tranny feels when you take off. You should be able to listen to the rpms of the engine and feel the auto shift. I've never really dealt with auto column shifters and repairing them. All, but two of my vehicles are manual.
Old Jun 24, 2004 | 11:58 PM
comet's Avatar
comet
Yeah, that's a col. problem most likely. The parts in the col. get sloppy over the years. The repair parts are pretty cheap and available from the vendors on this site.
Old Jun 26, 2004 | 02:01 AM
edselman's Avatar
edselman
Can you give me a idea of what to look for parts wise? Lets assume it is totally in need of a rebuild. I'm curious how much it would cost, because I would imagine I would get tired of shifting like that!
Dane
Old Jun 27, 2004 | 09:33 AM
PraiseolderFords's Avatar
PraiseolderFords
uh yeah, turning the corner and sliding into neutral sound slike no fun
Old Jun 27, 2004 | 03:15 PM
'70F100Owner's Avatar
'70F100Owner
I hate to steal the thred but I am having the same problem. Except I don't know about turning the column The P/O said it broke along time ago where you couldn't shift it into park. Now you can't shift it any. It's something in the column because I can shift through all the gears with the lever on the column under the hood. If I put that lever down into 1st, BTW C4 Auto, and put the lever in the truck down in 1st, I can shift up to reverse, but then you can't pull it back down with the lever in the truck. The P/O said he talked to a man about it along time ago and he said it needed a whole new column. I figure just something in there broke and could be replaced. So like edselman, I need some idea of what might need replaced, or if all would need replaced, what would it run price wise. I have a friend who owns a '72 and says he has taken his column out in about 45 minutes, so that shouldn't be a problem, but he doesn't know what might be broken. Thanks for any help. Sry for the long post.
Old Jun 27, 2004 | 05:14 PM
edselman's Avatar
edselman
I regret tossing that dennis carpenter catalog now Anyhow, 70F100owner, don't worry about hijacking the thread I bear no malice at all
J/K Hope you can get a answer also!!!
Dane
Old Jun 27, 2004 | 11:52 PM
hot1958's Avatar
hot1958
hey guy's,i think the problem is the bearing plate inside the column is bad.i hope you get it figured out/scott.
Old Jun 28, 2004 | 11:22 AM
orich's Avatar
orich
You guy's can post everything and still not give the right anwser only maybes!
The only true way is pull it down and check it out or go to the bone-yard and get one there.
(COULD BE')
1. Bad shift tube
2. shift lever end
3.shift linkage on tube loose
4.steering sector bushing
5.gearshift insulator bushing
6.???
my 2 cents
orich
Old Jun 28, 2004 | 11:43 AM
'70F100Owner
Thank you orich for your $.02. Now of those parts on your list, are they availible at Autozone and are they costly? I figure once the column is out it should be pretty straight forward to find and fix the problem. Just wondering on the cost of the parts or would it be more cost efficent to go buy a whole column out of a boneyard.
Old Jun 28, 2004 | 12:23 PM
FTE Ken's Avatar
FTE Ken
Or you can try checking with the sponsors:
www.autokrafters.com
www.macsautoparts.com
