1978 - 1996 Big Bronco
How to check for trouble codes
Old Jun 24, 2004 | 09:20 PM
BurlyBoy's Avatar
BurlyBoy
Hi all.
Anyone know how to check the trouble codes? I believe you have to jumper the connector and look for flashes in the cab with the "check engine light".
- what pins to you jumper
- what do the flashes mean?
cheers
1989 Bronco, 351w
Old Jun 24, 2004 | 11:47 PM
U_B_LO's Avatar
U_B_LO
In my '97 E350 van w/ PSD, you hook up to the female connector under the column. I hooked up a programmer, which also reads codes, to reprogram the computer module. You have the option of just reading error codes if you wish.
Old Jun 25, 2004 | 12:19 AM
BurlyBoy's Avatar
BurlyBoy
thnx, I'm looking specifically for how to read them without buying any special reader. I remember reading something about that a while back.
Old Jun 25, 2004 | 05:05 AM
daddydcs's Avatar
daddydcs
Everything I have been able to find requires you to use an analog volt meter for the test... if you have one let me know and I could look the pins up for you in my Haynes book!
Old Jun 25, 2004 | 11:11 AM
BurlyBoy's Avatar
BurlyBoy
OK, I finally found a great site on how to do this - took a long time. You don't need a meter, just use the check engine light in the cab.
http://www.off-road.com/ford/bigbron...eec/index.html
cheers!
Old Jun 25, 2004 | 02:15 PM
Lookinfurfun's Avatar
Lookinfurfun
cheers!
.....and a paperclip
