spark plug replacement - help!
Old Nov 7, 2002 | 09:09 AM
Opera House Works's Avatar
Opera House Works
Old Nov 8, 2002 | 05:17 PM
ltng7679's Avatar
ltng7679
Hi,
I've got a 1998 Explorer XLT with the 4.0L SOHC. How do you get the back right spark plug out? It is very very close to the AC/Heater plenum. Am I doomed to bring it to the dealer.
Thanks in advance for any help
Old Nov 8, 2002 | 05:50 PM
marragtop's Avatar
marragtop
Try getting to it thru the wheel well. You may have to jack the body up a bit. It works on the earlier Explorers, not sure about yours.
Mike
Old Nov 8, 2002 | 07:24 PM
kevincook's Avatar
kevincook
Thats the way. Jack it up and pull the right wheel, and remove the splash shield that is held on with push pins. You will not see it but you will be able to touch it.
Kevin.
