AC and overdrive problems
First let me state that my car is running fine. However, recently I have started having 3 problems.
1. For some reason the overdrive light keeps turning on and off. Please note that I do pull a 19 ft. boat from time to time. But this light is turning on and off even when I am not pulling anything.
2. I recently started noticing smoke as if something was burning coming out of the AC vents. There is no smoke in the engine and it smells more like freon. However, it is not the normal white mist you see when the ac is running real cold. It looks more like smoke from something burning but it does not have the correct smell.
3. On low speeds my car stutters a little. I will be at a light and when I hit the gas gas it holds back a little. This starting happening after I had a vacuum leak in the system. I might have run the gas too rich. I have placed numerous cans to clean out the system through the gas and it seems to have helped but not completely.
I appreciate any help.
nrvelasquez
