Sponsored by: Auxito
how to remove lpg kit
Old Jun 24, 2004 | 10:10 AM
sednec's Avatar
sednec
hi...i'm thinking to buy a 1997 f150 with after market lpg kit, my question is, is it easy to remove lpg tank and the kit, beacuse it is taking whole a lot of space in the truck bed and hard to find any lpg filling stations around here...
thank you..
this is an awsome message board
Old Jun 24, 2004 | 07:15 PM
Racerguy's Avatar
Racerguy
Is the truck dual fuel? By that I mean does it have a switch on the dash so it can run on either gas or LPG?
The first thing is to make sure there is no pressure in the tank. If you're not sure or if it does have pressure in it you should take to an LPG dealer or repair place and get them to bleed it off.
The tank and lines should come out easily by unbolting them. The mixer and vaporizer should also just unbolt. Hopefully the air intake hoses weren't butchered and can be hooked up easily again. The electrical part of it may be more complicated depending on what all they tied into.
