Oil & Lubrication
chevron vs. shell rotella
Old Nov 22, 2004 | 02:27 PM
simpleman's Avatar
simpleman
just an opinion on Royal Purple, fantastic oil although expensive. A close friend recommended - he has over 480,000 on his Dodge Dakota. I am pretty new to this oil analysis business but I run it in my Grand Cherokee. My PSD may never see it at 3.5 gal per change but I am totally impressed with Purple thus far. For my next oil change on the PSD I will be going with Rotella T
Old Nov 22, 2004 | 03:45 PM
Flash's Avatar
Flash
Ford390gashog, the Xw-40 is too heavy for use in the Triton engine. You are going to have hot spots develop inside the engine that is not going to show up on your temp gauge. I would suggest looking for the new 5w-20 oils. It will be rated as a 929 oil rather than a 153-H. Look on the back of the container for the spec. It is an even sturdier oil than the 153-H but it is new. You may have problems finding it- it's that new. There will be very little if any shearing. If the 5w-20 bothers you or you want to run a heavier oil, the 929's are also available in Xw-30. But don't put the Xw-40 in anymore.
Old Dec 2, 2004 | 11:53 AM
claw302's Avatar
claw302
5w20 Motorcraft Is A Synthetic Blend.
Ford redneck 09
Mar 6, 2015 01:01 PM
jmuenchow
17
Dec 16, 2014 11:24 PM
carl2591
Dec 6, 2014 09:58 AM
PSD6litre40
Dec 26, 2013 06:42 PM
TayzGpa
28
Oct 9, 2007 11:37 AM
