paintin the block
Old Jun 23, 2004 | 10:37 AM
shawnlee28's Avatar
shawnlee28
Talking paintin the block
wooohoo time to paint and assemble only i do not have a clue on painting or prep. i degreased the block and now i have a residue i cant seem to get off. smells like diesel.i have rubbed and rubbed with clean towels now i am thinkin some sort of carb cleaner might dry cleaner ? please direct me in the proper steps ?i dont want to have flakin paint in 2 months
Old Jun 23, 2004 | 11:34 AM
neverenough's Avatar
neverenough
I use carb cleaner to clean, then brake cleaner to prep, primer it with PPG's DP-40, then acrylic enamel colored to desired color to finish it.
Old Jun 27, 2004 | 02:14 AM
willd's Avatar
willd
I usually used lots of harsh soapy water and elbow grease. You have to get the bores really clean anyway and most solvents won't remove the trash from a boring/honing oil. If you are already assembled, then use carb cleaner or something like paint thinner, but don't smoke or do it where there is a flame present.
Old Jul 11, 2004 | 06:53 PM
coburnm's Avatar
coburnm
brake cleaner it what you want because it is desinged to leave no oil resiudue or anything like that.
