Had my V 10 for 8 months now and still have not looked at the owners manual.I see alot of post about hauling in overdrive I was always told this should not be done? Does it make a differance betweeen manual and automatic? When I'm hauling and get up to speed I put mine in overdrive, is this wrong? and how about climbing mountains unloaded. Mine is a 2004 auto.
I take mine out of OD when climbing and decending large hills. Keeps the tranny from searching for gears and engine brake effect when decending. I don't remember what the owners manual said. You should read it good info in there like the seat belt "dance" and door chim "dance".
Owners manual suggests that you can use OD all the time "unless" you notice a lot of shifting, then it is "recommended" to lock out OD, and haul the hills and mountains in drive.
Really not a very good explanation of what is going on and you can easily smoke your fluid unless you pay close attention to the tranny oil temp. The torque converter (TC) has a lock up clutch and before a downshift or up shift, the TC will start to do the lock/unlock dance and is noticeable usually only visually with the tachometer and not seat of the pants. The tach varies by only a couple of hundred RPMs, and when it does this, the tranny temp can climb to real HOT fairly quickly. Most of us that tow/haul a heavy load in the hills and mountains have learned to add deep trans pan, extra oil cooler, and temp gauge for trucks that don't have one. Keep the temp well below 220F and all is well.
BTW: Other than the deep cost in fuel MPG, these engines like pulling up the hill at whatever gear will get you to about 4500-4800 RPM and they will do it all day long!
I tow in OD always, if I'm going through very hilly terrain where the tranny hunts, I get out of OD. The shifting in and out of OD/converter lock-up causes excess heat, which as we all know is veddy, veddy bad for your tranny. When I'm in OD and have to apply enough accelerator to shift down and I'm going up what looks like could be a longish hill, I just hit the button to stay in drive. You don't want to accelerate enough to drop back into OD, then slow down enough to drop out of OD, etc, etc, etc. That's hunting, hunting is bad. Loaded or unloaded, the same thing applies, shift out of OD when you start going in and out of OD. I can feel my torque converter going in and out which is when I lock out the OD, although the converter will also lock up in drive if I remember correctly, Ken
How much work is involced with installing a trans temp gauge? Would it be "easy" while changing to a larger pan? I plan on buying a 32' travel trailer and want to do some towing upgrades.
Jegs, Summit, all those catalog guys have tranny temp gauges, with installation instructions. The cool kit is a Jegs kit with a temp gauge built in to the accessory cooler. It should be fairly easy to do if you have an automatic, good luck, Ken
