Sponsored by: Real Truck
hub nut size
Old Jun 22, 2004 | 10:41 PM
rlm02's Avatar
rlm02
hub nut size
does anybody know what size the front hub nut is on my 99 sd
thanks for any help
Old Jun 23, 2004 | 01:18 AM
DS02F250's Avatar
DS02F250
Just to clarify which nut exactly, are you asking about: (1) the hub for the 4WD; or (2) are you asking the size of the actual lug nuts themselves???
DS
Old Jun 23, 2004 | 07:37 AM
rlm02's Avatar
rlm02
sorry the 4WD hub nut thanks
Old Jun 23, 2004 | 09:26 AM
iskybantilus's Avatar
iskybantilus
hub nut? still not sure what it is your refering to. the axle nut, which is behind the hub? this usually uses a spanner wrench. maybe a small picture .. since there are always 10 names for every part on a truck.
Old Jul 4, 2004 | 10:40 PM
rusty350250's Avatar
rusty350250
I ahve a 99sd and there are no hub nuts. The locking hub comes off with a snap ring and a bit of tapping, there is a snap ring that goes on the stub shaft then three washers,metal plastic metal, assuming the rotor is off allready you can then remove the hub/bearing assembly, It has four nuts assesable from behind the knuckle, easier if you disconect the drag link from the side you are working on. don't remove the hub unless you want to replace a 35$ seal that goes around the stub shaft(it is the blue and white seal you see inside the hub when the locking hub is removed. The sixe is 19 or 20 mm if you need the exact let me know.
Old Jul 5, 2004 | 01:46 PM
rusty350250
I was wrong on my last post when i said the hub seal is in the hub it is in the knuckle. This way you can pull the hub and grease the punny axle bearing without pulling the seal
