Carb gasket help!
Old Jun 22, 2004 | 02:14 PM
edjar's Avatar
edjar
Question Carb gasket help!
I had my 1 bbl. Carter carb rebuilt and don't know which gasket to use when remounting it. The solid one or the one with cutouts on it?
Man am I dumb when it comes to cars. I'm only trying to get this '76 running for my 16 yr. old son.
Any help would be appreciated.
Thanks.
Old Jun 22, 2004 | 07:29 PM
mhg's Avatar
mhg
do you have an egr
if so then the cutout should be the one
if not then you may have a straight thru spacer and the plain gasket works
Old Jun 23, 2004 | 08:53 AM
edjar's Avatar
edjar
Sorry to be so dumb but what is the EGR?
Old Jun 23, 2004 | 01:52 PM
FordF150Fixer's Avatar
FordF150Fixer
Exhaust Gas Recirculator. A procedure where a small amount of exhaust gas is re-admitted into the combustion chamber to reduce peak combustion temperatures and thus reduce nitrous oxides emissions. I'm not sure if or not your '76 has a EGR valve.
Old Jun 23, 2004 | 03:36 PM
edjar's Avatar
edjar
will it cause any problems if I use one over the other?
