Factory Air Intakes
Old Jun 21, 2004 | 09:26 PM
ClemsonLightning's Avatar
ClemsonLightning
Factory Air Intakes
I've got a 94 Lightning that I recently installed the F-250 air inlet tube on and it definitely runs better at speed now, thanks to the ram air effect. I'm wondering if the diesels came with a larger filter and housing, and if I can fit it to the Lightning to get more filter area, and therefore less restriction. My current air box sits on the driver's fender, and exits into about a 3inch outlet.
Any info would really be appreciated.
Old Jun 21, 2004 | 09:36 PM
fai4g63's Avatar
fai4g63
A IDI diesel air filter will not fit on a EFI motor without some serious modifications. Actually if you could get it to fit it would hurt performance. There are a lot of aftermarket companys that make cold air intakes for the EFI F-series trucks. Look in the summit catalog.
Old Jun 21, 2004 | 10:04 PM
ClemsonLightning
My bad, I didn't explain myself well enough. I'm not going to use the diesel filter, just the larger housing with a K&N OEM style filter. Serious mods? Are they that much different? It should fit on the wheel well, but I don't know about the outlet...oh well. Any one recommend a good cold air intake?
Old Jun 21, 2004 | 10:11 PM
fai4g63's Avatar
fai4g63
The IDI diesels use a circular type air cleaner housing, just like a caburated gas engine uses. It is made to sit right on top of the intake manifod. Tottaly different set up from your truck.
Old Jun 21, 2004 | 10:34 PM
ClemsonLightning
ah....I forgot about those... Yeah, that def. won't work. What about the PS filter?
