HP on a budget
Old Jun 29, 2004 | 08:17 AM
daerhldgs2's Avatar
daerhldgs2
I agree with IVMOOSE007 that with the exception of headers almost anything else you do will move the torque band higher up the rpm scale and depending on stall in your torque converter and rear axle gearing this may still work great in your vehicle but without gearing changes will show up at very low rpm as a loss.
Old Jun 29, 2004 | 09:37 AM
94F150-408's Avatar
94F150-408
It greatly depends on the cam you deceide on, there are several that will increase your low rpn torque significantly.
Old Jun 30, 2004 | 12:28 AM
78bubba ed.'s Avatar
78bubba ed.
Im not really interested in low end that much, just hp mostly. its already got plenty enough as it is for what i need. but more hp would be nice. naturally aspirated hp.
Old Jun 30, 2004 | 12:59 AM
bigblocksix's Avatar
bigblocksix
start with headers and a good dual exhust, no cats if you can, then stick a k&n in the air intake, if thats not enough power for ya rip the motor out and build it with a good intake, stock ported heads, comp cams 268h cam and valvle train, flat top pistons and a fresh bottom end
Old Jun 30, 2004 | 06:54 AM
jwtaylor's Avatar
jwtaylor
78bubba ed.
YOu might wanna reconsider that. With a heavy vehicle you want all the low end torque you can get to go with that added hp. There is an old saying that goes to the effect of, horsepower sells cars and torque wins races. later
Chris1984
Jul 30, 2013 02:03 AM
biggreentank
33
May 8, 2007 09:22 PM
shockman
Mar 27, 2007 09:12 PM
Stars-&-Bars
Offroad & 4x4
Aug 27, 2006 09:53 PM
Rayolight
New Member Introductions
Feb 21, 2004 10:10 AM
