4x4 not workin
Old Jun 21, 2004 | 06:16 PM
96-5spd302's Avatar
96-5spd302
4x4 not workin
i hooked to our practice sled a lil bit ago to see what gear to pull in and my two front wheels wasnt pullin, i still have the automatic hubs and my theory was they froze up cause i hadnt been in 4 wheel drive in about 8 months, if so how hard is it to switch them to manual hubs, or to clean them and get them loosened up
Old Jun 21, 2004 | 06:55 PM
tellico racing's Avatar
tellico racing
Automatic hubs on a 73-79? Did you post this in the right forum?
Old Jun 21, 2004 | 06:58 PM
96-5spd302's Avatar
96-5spd302
yes im in the right forum, this truck is a 1 owner truck b4 i baught it, as far as i know i have one of the very few left with the automatic hubs on it, actually i have the only one i know of but yes automatic hubs are on it
Old Jun 21, 2004 | 07:07 PM
96-5spd302's Avatar
96-5spd302
yes im in the right forum, its a 79 3/4 ton, it was a one owner truck and he kept it all pretty much original, the lil blue light in the cab still worked that lit up then it was in 4x4., i had never seen that on another one either
Old Jun 21, 2004 | 09:07 PM
tellico racing
My brother had a truck with the blue light........but I have never seen the auto hubs on a 73-79.....certainly rare.
I would suggest converting the hubs to manual units.
Old Jun 21, 2004 | 09:11 PM
F150daniel's Avatar
F150daniel
is your T-case shift pattern like this?
lock
lo
N
HI
lock
if it is you have a NP203, it is a fulltime T-case and will allow slip between the front and rear if it is not locked. did you put in lock?
they didn't have automatic hubs in 79 they are full time hubs.
Old Jun 21, 2004 | 09:47 PM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum.
Old Jun 22, 2004 | 05:05 PM
96-5spd302's Avatar
96-5spd302
that is the pattern that my transfer case used to be, when i changed to the 4speed i changed transfer cases too and now i have, 4L N 2H 4H
Old Jun 22, 2004 | 10:20 PM
biz4two's Avatar
biz4two
Ok...now you have the NP205 transfer case. If you have a NP205, then you should have manual locking hubs. The conversion is pretty simple...and does not take that much time. WARN (premium) hubs are some of the best out there. The instructions that come with the hubs are straight forward and easy to understand. Good luck with your conversion...
TIP: If you haven't ruined your NP205 (probably not), jack the front of the truck up off the ground and put the transfer case in 4H. Now under the truck grab the front drive shaft and try to spin it. What should happen is that you feel a little resistance from the transfer case side. Also, your front wheel should rotate too. If not...then it is the hubs. While in the air...might as well try the 4L too.
Old Jun 23, 2004 | 04:36 PM
96-5spd302's Avatar
96-5spd302
biz4two, i done what u said, i jacked it up and the transfer case, i also jacked it up all the way around, started the truck and put it in 4wd, both driveshafts were spinnin but only the back two wheels were, so i guess my next step is puttin hubs on
Old Jun 23, 2004 | 09:44 PM
biz4two's Avatar
biz4two
96-5spd302 -- That does appear to be the problem, the hubs are just not engaging. A new set of part-time hubs...and you should be good to go! Good luck with it...
Old Jun 24, 2004 | 02:30 PM
Txquadhunter24's Avatar
Txquadhunter24
If it turns out you do have the old fulltime hubs on your truck and not the auto lockers like your stating. You may have more then a hub problem. Because the old style fulltime hubs are stronger then the man. lockout hubs. They just get swapped so better MPG running in 2wd raither the 4wd at all times. I wish you the best on having the auto hubs so you'll almost 100% know thats why 4x ain't workin.
