Trans. Temp?
Old Jun 21, 2004 | 02:40 PM
rcd771's Avatar
rcd771
Trans. Temp?
I just installed a trans temp gauge in my '99 F250 PSD. It has now mods other that some 305 Maxxis tires ant the Ford AIS. The temp read @210* on an easy 10-12 mile drive with no load and no large grades to pull (55-60 mph). This seems high, but I am not sure what temp is considered normal. Anyone have any suggestions?
Old Jun 21, 2004 | 02:52 PM
wlihntr's Avatar
wlihntr
that seems a little high. mine would run 150-175 around town with no load. it got to 220-230 pulling my camper and boat over some passes last year so i put another cooler on it. it still runs around 150-175 around town but now does not over 200 while towing.
Old Jun 21, 2004 | 04:40 PM
Craze's Avatar
Craze
210* - really? That does seem high. What brand gauge do you have?
Before I replace the trans cooler I was getting 150 - 160 normal no load.
Old Jun 21, 2004 | 05:45 PM
bigdieseldav's Avatar
bigdieseldav
180 is the highest i've seen no load. Thats was with it about 95 degrees outside.....
Old Jun 22, 2004 | 11:17 AM
rcd771's Avatar
rcd771
I am using Autometer gauges. The trans temp gauge is part# 2640. Thanks for the replies. Just not sure which way to go in resolving this situation. I don't know if I have a bad sensor, gauge, or if my 4r100 is just runnin' hot for some reason.
Old Jun 22, 2004 | 11:37 AM
wlihntr's Avatar
wlihntr
they will run alittle hot if there is too much trans fluid in them, maybe double check the fluid level...just a thought
Old Jun 22, 2004 | 11:58 AM
jharvey3's Avatar
jharvey3
when was the last time you had your tranny serviced? Could be time for some new fluid and a filter.
John
Old Jun 22, 2004 | 12:10 PM
Fire Rooster's Avatar
Fire Rooster
My advice would be to get an aftermarket tranny pan and a tru-cool max tranny cooler. My tranny runs 135-150 no load and 165 -185 pulling a 33ft toyhauler over steep mountain passes that is here in Phx AZ with temps from 95-115. I am very pleased with my set up.
Fire Rooster
Old Jun 22, 2004 | 06:04 PM
camperspecial65's Avatar
camperspecial65
Rooster, how many miles on your beast....would you advise relocating cooler a bit so its in air more as stock location is behind front lic. plate....How much for the pancooler kit....where can I find one???
thx, cs65
Still doing homework on this 99 1 ton.....
Old Jun 22, 2004 | 06:21 PM
Fire Rooster
40,000 miles, that cooler that is behind yur license plate is for the powersteering, The tranny cooler is behind the a/c condenser. So no leave it where it is and run the tru-cool in series with it. The larger tranny pan runs about 200.00 bucks and comes with a new filter and all the mounting hardware. For the tru-cool look up dieselsite.com and get the cooler, the tranny pan can be purchased through Hughes performance.
Fire Rooster
Old Jun 23, 2004 | 12:23 PM
rcd771's Avatar
rcd771
re: trans service
My trans was serviced about 200 miles ago.
Old Jun 24, 2004 | 10:19 AM
getnbz's Avatar
getnbz
i have that gauges also mine reads in the 150 to 170 range no load around town
