Offroad & 4x4
What Gear To Pull in
Old Jun 21, 2004 | 02:16 PM
96-5spd302's Avatar
96-5spd302
On my 3/4 Ton with the 4:10 gears and a healthy running 351M what gear would you guys pull in, Theres a pull comin up saturday and i am thinkin about pulling my truck for the first time.
Old Jun 21, 2004 | 03:27 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Whichever gear keeps the RPMs up high enough, doesn't spin the tires too much, and can pull the load.
Never pulled myself, just had to give a smart-alek comment
I'd think you'll be finding out which gear is best pretty soon ...
Old Jun 22, 2004 | 04:58 PM
78fordtruck's Avatar
78fordtruck
Most guys with less than 500 HP and stock transmissions have the best luck in low second. I have been pulling for 8 years and have finished second in points for the last 2 seasons.
Hope this helps
Todd
Old Jun 22, 2004 | 06:08 PM
ranger429's Avatar
ranger429
Just don't "lug" it down in a high gear! That is when stuff start's to come apart and clutch disc's start SMOKIN!
Old Jun 22, 2004 | 09:23 PM
scottie2hottie's Avatar
scottie2hottie
When my dad pulled his 78 351m 4spd he ran 4L and 2nd/3rd gear, depending on texture of track
Scott
Old Jun 23, 2004 | 09:45 AM
krewat's Avatar
krewat
It's not pulling, but in deep mud (up to the tops of the 31x12" snow tires), with sand under about 30" of mud, I made it through, repeatedly, in 4LOW in 3rd gear (435NP) with a basically stock 360 plus headers and 750 Holley 4bbl on 2bbl-to-4bbl adapter - had to run it around 3500-4000RPM to keep going. In 2nd, it wasn't possible to
Got it stuck and had to dig it out once, but I stupidly let off the gas in the middle of it.
Sounds like with 350+cid '73-79 is good at either 2nd or 3rd in 4LOW depending on how much traction and torque you have.
Old Jun 23, 2004 | 11:24 AM
fishmanndotcom's Avatar
fishmanndotcom
i always pull in 4Lo 2nd gear! but that's with an auto!
-cutts-
Old Jun 23, 2004 | 12:05 PM
78_351M's Avatar
78_351M
when my dad pulled his 1976 F250 ranger, 4.10 gears, 31'' tires, np 435, 390 (2) holleys, he used 2nd gear low side. he said it pulled good and can still remember how it pulled even after 20years
