1978 - 1996 Big Bronco
need help with brake pads
Old Jun 21, 2004 | 09:35 AM
Bob808's Avatar
Bob808
Tryng to replace pads on my 1990 bronco. Can't get calipers off, don't see any pins or screws. Seem to need step by step instructions. Anyone??
Old Jun 21, 2004 | 10:12 AM
The Tree's Avatar
The Tree
I'm not too sure about a 90 but on my 78' there was a bolt facing the rear of the truck, loosen that bolt, then there was a retaining clip beneath the bolt(the bolt holds it on) carefully knock out the retinaing clip. Then simply pull off the caliper in a rocking motion(I used a hammer). Now remember I have a 78 so you probably have to disconnect a ABS sensor as well. A haynes manual would explain it better.
Old Jun 21, 2004 | 11:15 AM
Crazyromi's Avatar
Crazyromi
http://www.autozone.com/servlet/UiBr...3d800d2d77.jsp
This link has the instructions for replacing the brake pads. Keep in mind that my 96, which is supposedly covered in these instructions, was completely different from this write up. Mine had two bolts in the back of the caliper attaching it to the steering knuckle. I would assume yours has the slides, but I don't know for sure.
Old Jun 21, 2004 | 12:07 PM
jacque_strap's Avatar
jacque_strap
I'm not positive, but pretty sure that your calipers are help together with pins. You just use a hammer and a punch to push them out and the caliper slides right off. Best of luck.
Old Jun 21, 2004 | 01:21 PM
buckeyebronco's Avatar
buckeyebronco
Take a pliers and squeze the slider pins together and have a punch and a BFH and pound them out. all there is to it.
Old Jun 21, 2004 | 07:20 PM
AYoungblood's Avatar
AYoungblood
Ill 2nd that, exactly how mine is, its a 90.
Old Jun 21, 2004 | 07:57 PM
Bob808's Avatar
Bob808
Thank you!! BFH worked, job all done!
Old Aug 13, 2004 | 12:14 AM
Swit's Avatar
Swit
Question Crazyromi ... How did ye do it?
I drug this thread out of the bin while looking for the 'how-to' on the brake caliper that *isn't* in the books.
Like Crazyromi's, mine has two bolts on the inner face of the spindle that the caliper rides on. There aren't any aft facing keeper bolts, no retainer clips to drive out as shown in the Chilton's (looks like the Autozone images.. but you can't READ the paper images in the Chilton's!) nor anything in the Haynes book for the beast.
Removal of the caliper isn't the big question right now. But, are you supposed to use the 8" C-clamp to bottom out the disc brake piston? (fixed end of clamp against inboard side, flat face of caliper and the screw/swivel pad end of the C-clamp on the outermost pad face? Or is there some other approved method??
Inquiring mind... and Bronco with foot in air..
Swit
'94 XLT, 351, auto..
Old Aug 13, 2004 | 12:53 AM
Crazyromi's Avatar
Crazyromi
You can bottom out the caliper, but you really don't have to. The first side I followed whatever directions I had about bottoming out the caliper and it worked, but it was unneccessary. All you need to do is remove the two bolts that hold the caliper onto the spindle. Then you can pull the caliper out, parrallel to the rotor. The rubber boots on the caliper bolts should give you enough wiggle room to move, and from there all that is holding the caliper is the metal clamps from the outer brake pad. Pull the caliper off the outer brake pad clamps, slide the back pad out, and reverse to install. I think that is all.
Old Aug 13, 2004 | 12:00 PM
Swit's Avatar
Swit
Crazyromi,
Aye, from the way this style of caliper/pad is arranged, just pulling the two retainer/slider bolts out of the back, removing the caliper off of the pads as you slide the caliper out/off of the rotor... and then slipping the pads out of the spindle/pad retainer springs seems the ticket. That leaves the caliper piston to be bottomed out with a clamp and pad (across the face of the piston) at your leisure.
Gotta wonder why this one isn't in the books though. This one seems to be a later model '94, the VIN is a B series, around the 33000 sequence ... which of course begs the question, "What is the SN range for '94 Bronco production?"
Trivia . I know.
Thanks again
Swit
Old Sep 17, 2004 | 11:50 AM
nowbiteme's Avatar
nowbiteme
after squeezing them together, do u punch and hammer the "pins" themselves .I cant seem to get the pins out. I have a 1989 XLT. These calipers are totally different from my car. That was easy to remove.
thanks.
Old Oct 25, 2004 | 02:10 AM
tom2131968's Avatar
tom2131968
You probably have completed the job by now but I was reading old posts so here goes:
Yes, squeeeze the ends of the pins together then punch them all the way through. The caliper will be free after you remove the second pin (obviously) I uses a 3/8 ratchet extension as a punch, works fine. Installing them is easy as well. Just pound the pins back in from the outside until the end is at the same position as it was before you started t remove it. Then, expand the end of the pin out so that it doesn't move. That's it
tom t
