Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Electric pressure washers
Old Jun 21, 2004 | 07:34 AM
Bruker's Avatar
Bruker
I'm thinking about getting an electric pressure washer and I would like to get one that shuts the motor off when you release the trigger. Who has one that does this and what brand and model number do you have?
One that I have my eye on is Home Depot's Husky Model #165019 1750psi for $179.95 it looks like a good deal. Anyone here familiar with it?
Old Jun 21, 2004 | 08:40 AM
jeffthompson's Avatar
jeffthompson
Mine was from Lowes and cost $89 (Karcher?)
Works great for cars, grills, pools & siding. 1300 psi.
Old Jun 21, 2004 | 09:46 AM
tmorris1's Avatar
tmorris1
They work OK, but the only problem I have with the electric ones is the amount of water they put out. They have good pressure, but not a lot of gallons per minute.
Old Jun 21, 2004 | 11:34 AM
75Player's Avatar
75Player
I have the Husky 1400 PSI model and it works great. The motor only runs when you pull the trigger, and for a couple seconds after you release it so the pressure get built back up. Already used it to clean the brick on my house, the gutters, driveway and deck. I also like that it doesn't use as much water as the gas powered ones do.
Old Jun 21, 2004 | 11:48 AM
Foneguy's Avatar
Foneguy
What's the shelf life on an electric pressure washer? I've heard that they don't last very long? Any insight would be great.
Thanks
Old Jun 21, 2004 | 11:52 AM
Sberry27's Avatar
Sberry27
What do you expect for a 179$ power tool like that?
Old Jun 21, 2004 | 11:58 AM
Sberry27's Avatar
Sberry27
[QUOTE=I also like that it doesn't use as much water as the gas powered ones do.[/QUOTE] Using water is what makes it clean. More water, more cleaning power. Pressure x volume of water = cleaning units. It also increases cleaning power when adding heat to the water.
