Any tips or advice
Old Jun 21, 2004 | 02:04 AM
Nick34's Avatar
Nick34
Any tips or advice
I have a 94 f-150 and I'm trying to swap out the original 302 with a 351W. I want to know what I'll need to change to do this. I don't think its as simple as just switching one engine for the other. Any tips or advice?
Old Jun 21, 2004 | 02:26 AM
Brettddglas's Avatar
Brettddglas
if you are using the whole engine they are virtually the same motor. head placement on the 351 motor is just a tad higher so you may have to get new headers made for the 351.
If you have a Mass air motor then the rest is easy. If not, you may have problems with the fuel management of the speed density computer. Check and see if the computers are the same on a 351/302 and if so you are golden.. if not, you will need a new computer or switch to mass air (and if you plan on doing mods to the motor you would find it advantageous to do it as well).
Other than that should be a straight swap.
hope this helps..
cheers,
Bdd
PS if you want to do a mass air conversion email me.
Old Jun 23, 2004 | 01:10 AM
Nick34's Avatar
Nick34
Thanks for the help, I'm definitely going to keep working on this motor. How tough is a mass air conversion and what will it do for performance?
Nick34
Old Jun 23, 2004 | 03:41 AM
lindsay's Avatar
lindsay
everything. it should be your first mod after the swap. check the other forums there are a couple about mass air conversions that will explain.
Old Jun 23, 2004 | 05:44 AM
Brettddglas
Exclamation
and if you would like to stay tuned, I will be doing it in about a week with pictures, editorials and everything.
Let me know if anyone is intersted. I will put it on my site.
Bdd
