I dont get this
Old Jun 20, 2004 | 11:54 PM
hermanMS's Avatar
hermanMS
I dont get this
OK i have just bought a f-150 4.2 and have ben having sum problems with it. The other day i turned on the a/c it was going good until i came to a stop and when i went to take off it had no power not even when i flored it. But once it got up to about 20mph it starts to go. i dont know what to do plez help thanx
Old Jun 21, 2004 | 09:30 AM
true4.2's Avatar
true4.2
Well, I think we need a little more info.
Is it stuttering like it just doesn't want to go...like it's 'clogged' or something?
How many miles does it have?
What year is it?
Did it make any strange noise?
Have you changed anything on it yet?
Have you checked all your filters, plugs, wires, etc...?
Is it an auto or manual transmission?
Is it a regular or supercab?
If it is an automatic, you won't have much power right off the bat in first gear. Once our motor spools up to around 2500-3000 RPM's, then our power starts to show. The manual also does not have 'tons' of power down low, but it is a little better IMO.
If it is a regular cab, you are much lighter than a supercab. A RCAB runs 17's stock and an SCAB runs 19-20's. (auto's) That's not all that fast. Just FYI
My recommendation, check everything first of all like the air filter, plugs, wires, and all that fun stuff. If they are dirty or worn, change them out.
Also, it all really depends on your defination of 'not going even when you floor it prior to the 20 MPH mark.'
