My first time, I'll try to do it correctly. Have '97 F150 S/C 4.6L
driver Pwr window no go up or down. Relay in Fuse block clicks when activating the sw. I swapped the Pass. side relay and still clicks. Driv. side relay works on the pass side window.
I've tried checking for pwr. thru the harness coupler after removing the door panel, I can't get pwr. there on the up or down activation.
I'd like to try anything before pulling the motor...I'd welcome advice or suggestions. Is there a "best " book or manual for this vehicle?
Houran
Just a little future ref. When you unbolt a bad window motor, and it falls to the bottom of the door, try it out again. Its likely to work agian. Those motors tend to wear a dead spot in there. Dropping it moves it off the dead spot......then works again.
