Whinning noise
Old Jun 20, 2004 | 05:02 PM
blr's Avatar
blr
Whinning noise
I have a 1998 F150 AOD 2wd, when going between 60kph to 80 kph there is a slight whinning noise when accelerating only, there is no noise at all other speeds , the noise is there even if you shift into third gear or overdrive, also there is a shudder at about 60 kph when either speeding up or slowing down. The axle shaft on one side , as well as axle bearings and rear end bearings were replaced about 35,000 kms ago. Any and all imput is welcome.
