Torque specs
Old Jun 20, 2004 | 02:27 PM
MJ23's Avatar
MJ23
Question Torque specs
Does anybody know the torque specs for upper and lower ball joints, tie rod ends, and the hub assembly bolts for 2000 4X4 excursion?
Thanks
OJ
Old Jun 21, 2004 | 01:19 AM
smassie88's Avatar
smassie88
Post
Below is as per Haynes manual;
Upper Ball-Joint Nut (2001 and earlier): 101 Ft-lbs
Lower Ball-Joint Nut (2001 and earlier): 101 Ft-lbs
Tie-rod end-to-steering knuckle nut (4WD models): 52 Ft-lbs
Drag link-to-tie-rod nut (4WD models): 67 Ft-lbs
Tie-rod/drag link adjuster sleeve clamp bolt/nut: 41 Ft-lbs
Hub bearing-to-steering knuckle nuts: 133 Ft-lbs
When you pick-up your parts for this jobs, pick-up a Haynes manual . You will refer back to this countless times when you are .
Old Jun 21, 2004 | 06:13 AM
MJ23's Avatar
MJ23
Thumbs up Thanks for the help!
[QUOTE=smassie88]Below is as per Haynes manual;
When you pick-up your parts for this jobs, pick-up a Haynes manual . You will refer back to this countless times when you are .[/QUOTE
I have not been able to find the haynes manual yet it would have helped save some time. All done know just need to torque everything down and get it aligned. I found the passenger side hub was blown up metal shavings everywhere ford cut me a deal I got it for like 340.00 also I unexcpectedly found the left and right tie rod ends to be completly froze my friend and I could not get them to budge at all. The new one's sure did move easily. Thanks again for the info. I am going to look online to see if I can get that manual. Regards, OJ
hhcobra
May 17, 2019 09:18 PM
GTOBRIAN
Apr 1, 2013 09:51 AM
4x4jedi
Jul 18, 2010 10:28 PM
Ed Davis
3.8 & 4.2L V6
Dec 21, 2003 10:21 PM
BB
Jul 19, 2002 06:07 AM
