Help with "check engine" light
Old Dec 1, 2002 | 08:44 AM
kshaw's Avatar
kshaw
I have a 1995 Ford Explorer that frequently displays the "check engine" light. Seems to run fine. I pulled the Key off OBD-I code of 214 which has something to do with the cylinder identification circuit failure. I have all the Helm's ford service manuals as well as the electrical circuit book and can't find anything on the circuit identification circuit or a diagnostic tree for this code. Anyone know the most likely cause for this code or how to track it down?
Old Dec 1, 2002 | 10:14 AM
maddog80's Avatar
maddog80
From what I can tell, it may be the crankshaft position sensor (CKP)or camshaft position sensor (CMP) - depending on engine type, the wiring between it and the PCM, or the PCM (least likely).
Your manual(s) should have a discussion on making voltage checks to determine whether the sensor is OK.
Old Dec 1, 2002 | 04:38 PM
kshaw's Avatar
kshaw
Thanks! That's a good starting point.
Old Dec 1, 2002 | 07:40 PM
CobraXP's Avatar
CobraXP
