240-390
Old Jun 20, 2004 | 10:05 AM
71 Sport Custom's Avatar
71 Sport Custom
Question 240-390
Hello, I'm trying to get my parts together to replace my 240 in my 71 F100 2WD with a 390 FE. I'm pretty sure I have everything. Do the towers get moved back? Does anyone know if the clutch Z bar from the 240 bellhousing will work with the FE bellhousing? Thanks, Doug
<!-- / message -->
Old Jun 21, 2004 | 04:56 PM
390fe's Avatar
390fe
< Do the towers get moved back?
I had to move mine when I replaced my 300 with a 390.
<Does anyone know if the clutch Z bar from the 240 bellhousing will work with the FE bellhousing?
Mine did, I think... It's been a few years though. Good luck!
Old Jun 22, 2004 | 03:10 PM
talisker's Avatar
talisker
I had to move mine to the rear when I replaced my 240 with a 360(same block as 390). The holes were already there. All in all it was a real simple swap. Good Luck!
Old Jun 22, 2004 | 06:04 PM
71 Sport Custom
Talisker, Was your truck a manual? If so did the Z bar still fit or did you search out a new one? Thanks, Doug
Old Jun 22, 2004 | 06:11 PM
talisker's Avatar
talisker
My original tranny was a 3 speed with a 240. I changed the tranny to a T-18 shortly after getting the truck about 10 years ago. The only change I made was to fabricate a bracket for the engine side of the Z bar. Some previous owner of the truck had welded the engine side bracket to the block. I cut tyhe shaft off, drilled the inside to accept a 7/16 grade 8 boly, fabricated a bracket and bolted the stub to the bracket. Actually, even though this only took a couple of hours it was the hardest part of the 240 to 360 swap.
