Front Crank Spacer
Old Jun 20, 2004 | 12:51 AM
78F150400M's Avatar
78F150400M
Question Front Crank Spacer
I have a 460 from a 68 or 69 lincoln that had a P.S. pump on the crank, and now is removed. I would think that the spacer I need does not have a counterweight on it. Am I right on this? I believe this is an internally balanced motor, but dont want to hurt something by having wrong info. Thanks in advance.
Old Jun 20, 2004 | 11:15 PM
neverenough's Avatar
neverenough
Yes, the sleeve is just a straight cylinder, no counterweight. To be sure, you can check the crank, it should have a 2Y casting code.
Old Jun 22, 2004 | 12:09 AM
bigwhtbco's Avatar
bigwhtbco
hgow do you get thisn thing off the crank?
