Clutch Linkage
Old Jun 20, 2004 | 12:11 AM
maximumhorsepower's Avatar
maximumhorsepower
Clutch Linkage
OK guys, somewhere in the process of putting in my new engine (built 390, YEAH!), I think I lost something. My clutch linkage is screwed up. my question is this, should there be a pivot on both sides of the Z-bar? I have a pivot with a bushing on the outside end of the Z-bar, but when I push in the pedal, the bar tweaks a little and gets stuck, so the pedal won't come back up? Is there a pivot that should bolt to the block to provide support? Does anybody have any ideas? or does anyone have pictures of their clutch linkage that I can take a look at? Thanks, I appreciate any input you guys have.
Old Jun 21, 2004 | 05:04 PM
390fe's Avatar
390fe
There should be a bracket that bolts to the block that has the other bushing for your z-bar.
Old Jun 22, 2004 | 12:58 PM
maximumhorsepower
any idea where I can find one?
Old Jun 22, 2004 | 03:04 PM
talisker's Avatar
talisker
I welded one up from scratch when I changed my 240 for a 360. It is just a shaft with the correct bushing. It is identical to the one that mounts to the frame except for the mounting. I had the bushing but it would probably be easy to make one.
Old Jun 22, 2004 | 03:12 PM
390fe's Avatar
390fe
If there's a salvage yard near you then any '65-'76 F-series with an FE and a manual tranny shoulh have one. I've got one, but I may be needing it in the future.
Old Jun 27, 2004 | 04:04 PM
maximumhorsepower
thanks guys
